I see nobody has stepped in to suggest interface options. There are some threads discussing the options. If you cannot locate them, maybe someone else will jump in to help you out.
I really do not know much about interfacing directly to KFlop... I was just trying to help you on some simple questions about coil surge suppressors.
I am sorry, I thought you were just starting. From searching for your posts I see that you already have something running with encoders.
If the list you added is all you need, then I guess you do not need KAnalog.
Here is the little I know about options other than KAnalog:
Winford Engineering was suggested to me for BOBS and relay boards.
Ebay and SainSmart have some inexpensive 2,4,8 and 16 relay boards and a couple of SSR boards, I have a couple, but I have not tested them.
http://umaxcnc.com/ has a smaller board. There is also a pmdx board. I do not know anything about them. I am sure there are more.
Yes, there are DIN rail devices. They are usually pretty expensive. If you have the $, then ask again and hopefully someone can tell part numbers and you where to buy them.
If all you have left to interface is what you listed, then you should be able to interface each separately without needing another big interface board.
Switches - Here is a thread on interfacing switches:
I am sure there are other threads that discuss more about switches and sample code.
With your noise problems, you may want to get opto-isolators and use 24v or 12v instead of 3.3v so noise will not be such an issue. Or you could get a 3.3v to 5v logic level converter (LLC) to bring the votage up above the noise more and help protect the KFlop inputs. However, I do not know where to buy a converter with terminals.
For your probes, you need to know what voltage / signals they output before you can figure out how to interface them.
For you coolant pump. You seem to already be switching it. So, yes you have to put a suppressor on the coil. If that does not solve the problem from it, it may help to add a resistor - capacitor from the contactor output terminals to cabinet ground. However, I do not know much about that... :)
Contactor/relay and motor noise problems are not specific to KFlop - there is a lot of information about suppressing noise on the net.
You have to have suppressors on all of your relay/contactor coils. DC coils just need a reverse diode and AC coils need an R/C.
Good luck. I am sorry I could not be of more help.
Dean
--- In DynoMotion@yahoogroups.com, "ericncn" wrote:
> Yes I was talking about the enclosure door!
> If the KFLOP is moved to the enclosure door and the door must be able to open/close normally, the cables connecting the KFLOP to the motor drives would need to be quite long!
> --- In DynoMotion@yahoogroups.com, "deanw1a" deanwyant@ wrote:
> > I guess it depends on which holes in KFlop you used.
> > You would definitely need to add two more risers out at the far corners of KAnalog. The manual has the hole patterns.
> > I am not sure I would do that.
> > I mentioned "the door" thinking that your enclosure where KFlop is located might have a door.
> > I'll let someone else address the KFlop LVTTL interfacing options.
> > Good luck.
> > > Thank you for the clarifications. It looks like if I could use the KANALOG it would probably solve most of my needs;
> > > I do not have those 3.5" clearance around the KFLOP and moving it to the door together the KANALOG would require running long cables to the motor drives, not sure that would be good.
> > > 1" long(er) risers would put it above the other stuff and could do _IF_ KANALOG can be bolted on same hole pattern of KFLOP and that would be stable enough (talking about mechanical stability with the long risers).
> > > Talking about the I/Os I need (apart encoders input and analog outputs), my current needs are:
> > > - home/limit switches
> > > - emergency button
> > > - tool height setter
> > > - probe
> > > - a relay for controlling the coolant pump (220V AC 33 W)
> > > with proper "suppressor" (like I described in other posts,
> > > this pump is disturbing the system when switching on/off)
> > > later I'll need to add:
> > > - read more switches
> > > - relays for controlling solenoids (pneumatic)
> > > Would like some suggestions about what kind of DIN rail mount stuff I could use for interfacing these to the KANALOG,
> > > but also what could I use to interface directly to the LVTTL pins of the KFLOP (if anything exists) ?
> > > EC
